conventional boiler and PRV
22 Jul 2017
I assume that a conventional boiler doesn't have a PRV so if you are going to pressurize the system where do u put the PRV , with the pressure vessel going in the airing cupboard?
Is it a case of putting one in the pipework near the boiler or should it be near the pressure vessel or doesn't it matter? thanks
Thanks Ian
Boiler would probably be a WB 12ri.
If the pressure vessel was to go in the airing cupboard which is not on an outside wall then I presume that a copper pipe would have to run from the A/C to an outside wall for discharge?
What is O/H. ?
Sorry @rhinosaw O/H is over heat thermostat, but if a Worcester Ri it already has one so no need to worry, the PRV discharge can go outside or into an internal drain if you install a tundish, PE pipe if high temp rated can be used, if running to outside you dont need a tundish, but good practice to fit one anyway, they are not expensive
Thanks again, have heard of tundish, just remind me what it does, thought it was to do with vented HW cylinder
It is simply a way of visibly noticing that water is passing from the Pressure relief valve, yes used on unvented mostly but not exclusively, it is simply a bit of , Plastic usually, can be brass too though as well as other materials, as said only required if you are connecting to a drain, but good practice to fit even if terminating outside.
https://www.ebay.co.uk/itm/15mm-x-2...361645&hash=item3636dfcc4d:g:0~AAAOSwaK1bSc24
Thanks, I have another question regards system boilers, will start new thread
