- Joined
- 14 Sep 2015
- Messages
- 44
- Reaction score
- 2
- Country
Hello All,
Currently the house has 2 large flats and an existing 32mm lead water connection. The plan is to divide into 5 smaller flats (4 x 1 bed, 1 shower and 1 x 3 bed, 1 shower).
Recently, Severn Trent were out to replace the stop cock as it was faulty and asking the workmen, their view was that the existing connection is ample, in addition, Severn Trent seem to want several thousands for 3 further water connections.
The existing 32mm seems to reduce down to 15mm copper where the internal stop cock is. I have put a pressure gauge on and measured a static pressure of 3.5 - 3.8 bar.
Therefore, I was thinking to first try using the existing connection by leaving a bit of the lead pipe from the stop cock, cutting and joining/replacing the rest with 32mm MDPE, then using a manifold to branch off 5 x 25mm connections.
Thoughts?
Thoughts?
