- Joined
- 29 Mar 2023
- Messages
- 5
- Reaction score
- 0
- Country
Have read and read many similar threads but still have some questions.
Am wanting to convert an attached garage built in 2003. External wall is cavity brick/block and trench foundations.
In the middle of the existing garage door opening runs a foul sewer at about 1100mm depth, running front to back of the house.
The house is an end terrace and the sewer serves 4 houses
The floor of the garage is DPM and concrete slab.
The proposed wall and window to replace the garage door, will be built perpendicular to the sewer.
Where the garage door was inset by 1000mm the wall will be flush with the front of the house.
The wall will be cavity brick/ins/block, on trench foundations to invert + 150mm, and a bridging lintel
Questions
After doing a lot of reading, I am less clear concerning the need for a buildover agreement with Thames Water.
I had thought it could be self cert, did the questionnaire and am given full approval required.
This annoyed me, and I got to thinking. The substantial slab and existing foundations were approved in 2003.
Does the change in use of the garage therefore need a buildover agreement as the sewer was already built over in 2003.
To confirm there would need to be foundations dug, whish the sewer pipe will pass "through"
Any opinions/experiences?
Cheers, Nic
Questions
Cheers, Nic
