Hi all,
I am wondering if anyone can give me some advice please.
We have replaced our boiler and at the same time converted from semi-gravity to fully pumped. The y-plan layout now includes a separate pump and a 3-port valve.
It all works, but there is a loud bang happening frequently which I can reproduce manually as follows:
The CH and HW are hot, everything good, the pump has switched off.
There is a little lever on the 3-port valve for manual switching. I pull the lever on the 3-port valve into the HW position. As the HW is hot enough, the lever immediately starts to move back to the CH position, slowly. As it is switching, this is exactly the point when the bang happens. The bang comes from the pipework further away in the house.
When I switch on the pump and do the same test again then there is no bang. The lever is also easy to pull while the pump is running.
The pump has settings 1, 2 and 3. Running it at 2 makes it bang louder than at 1, presumably increasing the pressure.
I'd be grateful if you could help.
Regards,
Ol
Regards,
Ol
