converting a garage
25 Aug 2004
Cornwall
to make it a bedroom
the garage is attached so the house side (lhs looking in) is cavity wall
the rhs is single block
the rear is single block
to maintain the area we use for laundry the bedroom will not be the whole depth of the garage so there will be a cross wall between the bedroom and the laundry area
the bedroom will have an ensuite toilet with handbasin
the floor of the garage is concrete and 150mm below the house floor level
the roof of the garage is made of timber trusses and at present is boarded to take some storage.
the garage has light, power, hot and cold water supplies
re: insulating the single brick walls and floor of the garage, creating a ceiling and insulating it
what is the best method to do these things?
the electrics will be revamped and some minor plumbing for a saniflo
i will be using trades to do the work except the decorating and flooring
cheers
geof
