I have a Worcester Bosch Greenstar 24i system boiler running on LPG installed in my property and considering converting to natural gas, how easy would it be for my installer to convert the boiler for me.
You might need a conversion kit, although this may depend on the age of your boiler, WB have had three or four attempts at the 24i System and whilst some of them definitely need a kit I'm not certain that all of them do. Either way, a certain amount of twiddling by a Gas Safe man with a flue gas analyser will be required
Your gas pipe to the boiler may well require upgrading as NG runs at a lower pressure than LPG.
£700 is cheap to have a NG supply run to your house though, I'd get it done regardless of whether you're going to use it immediately or not if I was you
