Soon after I installed my new oil central heating system (open vented) using a Danesmoor 15/19 boiler I was advised I should have installed it as a sealed system.
I hope to get round to converting to a sealed system shortly but am hoping someone can give me some advice.
As far as I am aware it is a fairly simple job. In principle all I need to do is remove the header tank in the loft & replace it with an expansion vessel. At the same time I need to fit a pressure release valve.
I assume it is not important whereabouts in the system these new components are fitted?
I note Screwfix supply a range of expansion vessels 8 12 18 and 25 litre. How do I decide which size is most appropriate?
Thank you
Mike
Thank you
Mike
