At the moment i have a Bristan Bliss 10.5 Kw electric shower, which is good but when i come to having my boiler replaced with a combi, this leaves me with an expensive to run shower compared to the cheaper hot water from a combi (and probably better flow)
For the electric shower there is only 1 pipe coming down through the wall for the mains cold water (and the cable) but if i were to change to a mixer then i'd obviously need 2 pipes for hot and cold. Short of removing the tiles trying not to break them, running another pipe, finding mathcing tiles to replace etc etc. Or running pipes on the surface is there any other product which i could use instead?
I was thinking a remote controlled mixer in the loft with the outlet pipe coming down the wall with some kind of outlet valve like you get on concealed showers.
is that even possible?
