In my garage I have a pendant light which is controlled by a switched FCU taken direct from the power circuit.
I want to replace the pendant light with 2 flourescents and make the switch 2 way (the current switch is by the back door and I could do with one by the garage entrance also).
I am assuming you can't get 2 way switched FCU's.
I have looked at the wiki for 2 way lighting and there seems to be different ways of doing it.
My initial thought would be to make the FCU unswitched and take the load into a junction box then from there to the light and switch and then take a 3 core from the switch to the other switch. Is this the best (easiest) method.
The garage is attached to the house so I am not too sure about the legalitites - advice also welcome on this issue too please.
Many thanks
Carol
Many thanks
Carol
