Goin to start this in July, drop kerb organised from county council. I have seen concrete bricks recently laid with some sort of micro gravel in between each brick. Isn't sand in between allowed any more?
I thought that since the laws had changed in Oct 08, you cannot lay a hardstanding and let the surface water run off your property, if you lay an impervious surface, you must install a drain and soakaway, if you lay a brick drive (as I intend to) you must increase the gaps between each brick so water drains between them more effectively. Am I wrong?
