I have an oil fired boiler with two outlets one for central heating which is pumped. The other is gravity feed for the HW.
The HW has a moterised valve.
I want to add a pump to the gravity feed principally to use the HW circuit as a dump for excess heat generated by solar panels. This is to stop the likly-hood of the pressure in the system exceeding 3bar and venting. This kind of occurs when we are away for a few days and we get hot sunny weather.
I am looking at adding a pump on the return pipe near the HW cylindar. Is the siting of the pump sensible? if not where should I try and site the pump?
Is a by-pass loop necessary as the pump should only ever run when the valve is fully open? The boiler only turns on when the valve is fully open or the central heeting is on also the radiator in the bathroom is setup to provide a heat dump when all the valves are closed and the boiler is running.
The controls for the Solar system and a little bit of electronics will ensure that the pump will only run when the value is fully open. I have all the cabling necessary near the cylinder but I don't have access to the solar system relay's near the boiler without running another cable 3 stores.
Damian
Damian
