converting Gravity to F/Pumped
17 May 2010
Surrey
Asked to fit W/Bosch 24ri (client supplied) in place of Kingisher2 Mf with gravity H/W on C-plan with single combined cold feed/vent on primary flow @ cylinder.
Not possible to run new primaries due to laminate floor, so looking for solutions to convert to fully pumped.
1. Simple solution convert to sealed system with S-plan
2. Any other suggestions like pump on return nr boiler with valves & auto by- pass before it. Not sure honeywell like that set up & poss problems with combined feed/vent ??
3. Just like others views on possible solutions to the problem of not having access to pipework between boiler & cylinder when doing boiler changes with gravity circuit. Sometimes the age of a system puts me off using sealed systems !
Thanks for any comments.
