Converting gutter downpipe into new soil pipe
21 Sep 2009
Worcestershire
New extension going in with an En Suite. I'll need a new soil pipe with it, but realised there's already a gutter drain near enough to it. I've been trying to work out if it's connected to the sewer, without as much proof as I think I need...
I put a hose down the drain and after a while, water runs slowly through the sewer past the manhole cover, only 2m away. And it takes a long time to stop afterwards. This feels like it might just be blocked from moss falling down the drainpipe over the years? this drain pipe is directly inline with the one on the front of the house so I think they're connected in a straight line under the house, but I'm half baffled about why the water I see in the sewer only "sort of" matches what I put down the drain. It also sounds quite echoey down the gutter drain... as if there were some sort of chamber down there?
Ideally I'd like to prove this is just a bit blocked up and I could replace the drain pipe with a full soil pipe, and run the existing gutter into it, and not need to dig a new trench to connect to the manhole... I can do it if I really have to, but I'm hoping someone might be able to guess what's going on underground from my description?! Do I just need to get it properly flushed through by force to make it behave like I think it should?
Cheers
Use green drain dye to be sure. If it's that slow though it could be leaking from one drain to another.
