Hi all,
I'm in need of some advise regarding my plans to officially convert our loft room to a bedroom in our new house. The room has been used as an unofficial bedroom by the previous owner but there are quite a few cracks in the ceiling below which I feel are due to the inadequate joist size.
The room is 4250x7000mm and the joists run front to back (so 7m) not across and they are supported at the center by a stud wall, the joists are 110x75mm at 380 centers. So I feel they are totally inadequate and won't meet building regs.
The ceiling height of the floor below is 2420mm and I don't want to lose headroom in the attic so its my plan to hopefully fit 2 steel beams below the joists to support them.
I need to know the max span of the existing joists so I know where I can place the beams, ideally they would be able to span 2700 so I can avoid the staircase at 1 end and avoid the shower at the other end of the house, I've looked on the 1992 building regs span table but they don't cover this size, can anybody help me with this...
I hope this makes sense.
cheers Antony
cheers Antony
