I am past 70 years of age and I have a large loft area which my wife refuses to access because it make her claustrophobic so if I become unable to access the loft we will be unable to access any of the items up there. We are also running out of storage space downstairs and I am find it increasingly difficult to access the loft by loft ladder.
I therefore intend to convert the loft space to use for general storage and for working on my computer. I do not intent to claim that this will be habitable space and if I ever sell the bungalow it will be classed as accessible storage space.
The loft floor is covered with chip board and until I removed it the loft was stacked out with the belongings of my three sons which are not half the weight of the computer equipment I intend to install. The floor area supported by the ceiling joists is about 4M as a passage runs through the centre of the bungalow.
It is my intention to install a set of stairs to access the loft, to install two velux windows and insulate the area by placing some sort of rigid insulation about 100mm thick in-between the roof joists and round the space that I intend to use. The ceiling/loft joists are 80mmX50mm but as I said they have taken the weight of all the stuff from my sons but I know that they could do with being thicker.
I have two questions:
1. Would it help to strengthen the ceiling/loft joists if I were to screw another 80mmX50mm to the ceiling/loft joists or should I install additional 80mmX150 ceiling/loft joists?
2. When I place the 100mm rigid insulation between the roof joists should a gap be left between the insulation and the tiles?
