I am in the process of purchasing a large end terraced house which has main road frontage to the gable end with door & windows on ground and upper floor.
The side of the house is on a side street at right angles to the main road with a bricked up door but windows on this elevation.
The other two walls are party walls with adjoinining properties except for a garage which passes through to a communal car parking area but no windows etc.
I would like to split this property into two smaller terraced houses .
Do I require solid construction walls between the 2 halves (ie brick/block) from ground floor to roof?
Do I need more than 1 form of access for each property?
Would a passage way through the garage suffice as a joint/shared 2nd access/escape route should one be required?
Thanks Ian
Thanks Ian
