- Joined
- 7 May 2024
- Messages
- 27
- Reaction score
- 1
- Country
Hi all, we are planning on converting a single brick skin outbuilding into a downstairs bathroom with access via a newly installed door in the kitchen.
The outhouse is big enough to create a completely separate internal stud wall with 100mm kingspan (or similar) so that we can allow the external bricks to breathe.
The roof is pitched and tiled with rafters exposed. We plan to create a lowered ceiling again with 100mm insulation, leaving the roof void above to breathe and hopefully prevent condensation etc.
The original door will be bricked up and the window size reduced and replaced with a triple glazed unit.
Floor will be insulated as it's currently lower than the house floor level so this will level it out and hopefully stop the cold.
Is it likely this combination of works would be approved by building control?
Our local BC department aren't willing to give you an opinion on whether chocolate would melt in a hot oven unless you pay for the privilege of asking a question!
Thanks for any input.
