Converting TV power lead to IEC connection
18 Sep 2017
I currently have a figure 8 power lead in a cavity connected to a plug point I had assumed that my new TV would have same connector. However it has a hard wired lead with standard plug I can't plug it in to the power point as I can't get it through the cavity
I was thinking of getting an adaptor to change the figure 8 connector to an IEC one
https://goo.gl/images/d4G7NA
I could then replace end of lead coming from TV with a corresponding connector. The Sony power is non earthed
Is this OK to do
Yes if the TV does not require an earth connection. Check you have the space for the adaptor !
Dave
Or you make up an adaptor with a re-wirable female IEC connector one end, and figure 8 the other.
I note I can buy a IEC connector which you can wire directly so can fit that to the end of TV hard wired lead. However I can't find a figure 8 connector so was thinking of buying a figure 8 extension lead and cutting the end off and fitting a male IEC connector at the end. So I then connect that to the existing figure 8 lead and plug other end into the IEC connector on TV
I was looking at connectors for attaching an IEC to figure 8 extension lead and found these on Screwfix
https://www.screwfix.com/p/debox-in-line-connector-box/8692h#product_additional_details_container
I assume that it makes no difference they are not rated 32amps as the wire I am connecting to has a 5 amp fuse at end
In fact if I just buy a figure 8 extension and one end off and connect the other end to the TV lead I could then simply connect the female other end to the exiting male figure 8 I have
Is there anything wrong with that idea
