converting window to patio doors
Status
Not open for further replies.
25 Mar 2010
London
the guys who fitted my double glazing say they can install the patio door which they are supplying, i dont think they are fully competent to do this as this requires some knowledge of building works i.e damp proofing and cutting the bricks below the window with dimond discs. is there anything else i could ask them to establiosh how exactly they will be doing the job or things i should look out for.
many thanks,
any advice/comments much appriciated.
Also bear in mind...
An external window or door is a "controlled fitting" under the Building Regulations and as a result of this classification these Regulations set out certain standards to be met when such a window or door is replaced.
You could use an installer registered with a competent person scheme (BSI, CERTASS or FENSA). A registered installer will be approved to carry out the work to comply with building regulations without involving local authority building control. When work is complete you will receive a certificate showing the work was done by a registered installer. More information about Competent Person Schemes can be found on the CLG website.
Alternatively, you could use an unregistered installer or DIY, in which case approval can be sought from the relevant Building Control Body – either at your Local Authority or an Approved Inspector. They will check the replacement window(s) or door(s) for compliance and, if satisfied, issue a certificate of compliance.
http://www.planningportal.gov.uk/en...orkcommondoorwindow/workmorebregsdoorswindows
Status
