9.0 KW cooker
20 meter run
10 mm cable
40 Amp breaker
Is it possible to attach 6mm cable from the cooker outlet point to the cooker even though the rest of the run is 10mm ?
the reason I want to run 6mm is because there is not much room at the back of the cooker and was thinking pulling and shoving the cooker in and out may stress the cable but with 6mm being more flexible that would be better.
It was also suggested that I could use 4mm butyl ???.
thanks
20 meter run
10 mm cable
40 Amp breaker
thanks
