Hi all,
My old gas cooker just failed the Landlord's annual safety regs, so the landlord has just delivered a brand spanking new one which the gas people are going to swap over and install on tuesday. However, I have an electrical query.
The old cooker had no electrics (manual lighting etc). The new one has electric ignition and a light for the oven (ooo-ee!), however, it has a standard flex with a 3 amp plugtop to supply these features.
My problem is that I don't have an available socket to plug it into. I do, however, have a cooker control unit (and associated outlet at low level) for use with an electric cooker.
My first thought was simply to chop off the plug and wire the flex directly into the outlet behind the cooker. But that takes the fuse out of the scenario. So then I thought about changing the fuse for that circuit at the CU, but as mentioned, the socket on the cooker control plate is in use - for my toaster! So that wouldn't work either.
The new idea is this - I take a 1 gang extension cable and chop it off 6 inches before the socket end. Wire this into the outlet behind the cooker. Plug in the cooker (3A fused plugtop intact) and away we go.
Just wanted confirmation that this is safe, or alternative ideas, before the gas people come on tuesday.
