Although we don't have an electric cooker, I would like to install a supply for one.
The Problem
The only path for the cable is, from CU through outside wall under soffit, (converted bungalow) along wall below soffit, down and through wall to cooker switched unit. Total lenth of cable is approx 15Mtrs. A 45amp spare MCB is there, and CU has 80amp 30mA RCD All installation would be in steel conduit or another recommended method.
Can this be done legally, and what would your recommended method be.
Thanks for ANY help/advice you can provide.
The Problem
