I need to wire in my son's new NEFF oven. The instructions say use cable type H05VV-F but this cable appears to come in various sizes/current ratings.
The current oven is wired into a junction box with a cable of a similar size to the cable on your average TV, except it has a black rubber sheath. The junction box is switched via what looks like standard on/off switch set in a square panel, which is mounted into the wall (similar to an everyday light on/off switch)
Any views on what this H05VV-F cable is and what size should I be using.
Is there an equivalent from your average DIY outlet?
On the side of the oven it mentions 4.3KW which in my book is around 18 Amps so is the switch in current use OK?
