Just started doing some maintenance for a landlord & the previous electrician had done PIR's in all the properties. Been running through the list of jobs & one of them is "no rcd on cooker circuit" (it has a socket)
Now I could replace the double cooker switch with one without a socket but it would be on its side & that would look crap. (Can you get double cooker switches that fit horizontally with no socket ?)
The CU is an old Crabtree with type 1 cb's. I could put a small CU with RCD next to it & route the cooker cables into it but I would have to extend the cables, new tails, henlys etc
I could put an RCD in the incoming tails but that could open a can of worms! (The sockets are already on an RCCB)
What would you do ?
What would you do ?
