Hello, a quick question hopefully as I'm in the middle of doing the job!!
I've fitted the cooker switch to the side of the cooker position above worktop height, I'm now doing the connection box position, I would like to place it in directly below the switch then run the cooker cable to it, this would mean the connection box is to the side of the cooker rather than behind it. Is this OK??
Just makes running the cables easier, I was going to run the 6mm twin & earth cable loose in the wall behind the insulated plasterboard.
It would look exactly like the pic in the post below!
Any thoughts?
Thanks.
Any thoughts?
Thanks.
