Hi there peeps! Hope someone can help.. I've recently moved into a rented property. Kitchen has Belling gas cooker (4 hobs, oven & grill). On inspection it seems the separate cooker circuit has been closed and a 13A plug has been put on the cooker. Is this safe??
Cheers 4 post - this is my 1st response.
I'm a novice at this forum & even more of a novice when it comes to electrics.
I'm also a Single Mum & my Son has Special Needs - I think only a fool would ignore Regs. I would rather avoid a potential fire/electric shock hazard!
