Hi all
Just a question about fitting a DP switch for a hob and oven.
When we moved into our house, we kocked a wall down in which was part of the cooker circuit attached to a cooker connection unit. The cable has now been shortened and resides between the floorboards! Is this acceptable - its not attached to anythig, it just sits inbetween the boards.
If this isn't correct, what needs to be done to correct it. Also, A bloke fitted the cooker; it is a hob and an oven. The cooker circuit is a 10mm TE cable, it goes to the connection unit and from this unit comes 2 x 2.5TE cable to the oven and hob. Again, is this ok?
One other question. As the bloke connected these to cables straight to the cooker, there isnt a switch above the worktop to isolate the oven and hob. Would it be acceptable to fit 2 45amp DP switches for each appliance (oven & hob) above the worktop?
Any comments would be gratefully be received.
Cheers
M
Cheers
M
