Does anyone know what the minimum distance should be between a cooker hood extractor vent and a boiler flue vent? My plumber has put the new cooker hood extractor vent 6 inches away from the combi boiler flue.
The boiler is a Volkera, about 10 years old The cooker hood is a baumatic, brand new
The cooker hood vent (outside wall end) has a plastic flap on it that closes when the fan is not running. The pipe from the cooker hood to the hole in the wall is at least 6 foot in length if that makes any difference?
lor - isn't the requirement the same as for the distance from the flue to an opening in the wall (eg a window / door). I didn't realise there was any relaxation if the duct contained a non return flap? Who is to say the non-return flap will not stick open or forms an airtight seal in the first place?
As noonespecial said, the regulations have to take account of the possibility of the flaps failing/breaking off and the fan not running, so it must be regarded as a potential air inlet like any other.
