Morning everyone,
I've removed a wall in my 1930s semi to create a kitchen dinner, the removed wall had a chimney running up it which has also been removed as far as the new RSJs (one either side of the chimney,,, a different story!). The idea being to have the new hob on a peninsular where the wall used to be and have the cooker hood hanging down from the RSJs, venting up the chimney.
View media item 70237 View media item 70238
I'm a bit concerned about condensation and grease etc in the chimney.
There is a steel liner which runs up for the first metre and a half or so then just brick work.
I'm thinking of dropping a PVC flexible (as the chimney zig-zags at the top) duct down the chimney from the top and putting a suitable weather cover on top. Its about 6m so will need to find a hood that can deal with that.
My concern is that the chimney (outside the duct) will effectively be sealed and not be able to breath. is this a problem?
Does what I'm suggesting sound like the way to go? or should I stop worrying and just attach the hood to the steel pipe?
Thanks for reading,
Joe
Thanks for reading,
Joe
