- Joined
- 11 Jun 2016
- Messages
- 46
- Reaction score
- 1
- Country
Hi all
I've just purchased a cooker hood (Zanussi ZHC6234X_SS) from ao.com to replace my aged and grease ridden integrated extractor.
My old extractor was plugged into a socket hidden above itself. I assumed my new cooker hood would screw onto the wall and I'd utilise the socket (which is on ring main). However my new hood doesn't have a plug, just a flex.
I've read lots of forums on this and most suggest putting a plug on the flex with a 3 amp fuse. However the Zanussi website says 'fuse size: 10' and ao.com tell me it should be fused at 13amps - presumably because 10amp fuses are not easily available??? (not to my knowledge anyway).
My other thought is to replace the socket front with an FCU, keep the ring main complete by using the 'L and N in' and the use 'L and N out' to connect the cooker hood flex. However I'm still not clear what size fuse to use.
Total wattage = 220 (180 fan and 2x 20w lights)
What do people think?
Thanks for your time in advance.
