We have the following cooker hood:-
http://www.currys.co.uk/gbuk/built-...UbtPcQAABe1p@1De:20130826163239:s#prd17316295
We've had acoustic insulation put in the cavity between the kitchen ceiling and the bedroom floor above. We're sensitive to noise and have therefore had the full cavity installed with acoustic insulation, which meant that the venting pipe that took the air from the cooker hood to the outside has now been realigned. However, whilst it has been realigned, the end of the venting pipe that would have attached to an outside wall is now just sitting loose underneath another of the upstairs bedrooms.
The chap who carried out the soundproofing works has suggested that we just replace the filters in the hood with carbon filters and we'll be able to run it as normal, and that there won't be any problems with either (a) the hood (e.g. burning out), or (b) a build up of moisture/air underneath the other upstairs bedroom (where the end of the venting pipe is effectively just sitting loose).
Is this correct? Or do we need to remove this cooker hood and get a ductless hood installed?
