Cooker Hood Help
14 Feb 2011
I have a dilemma.
I have had a kitchen extension built and the roof is a vaulted ceiling at 15 degrees. The point where my cooker is going, the roof height is 2m high, and with the height of the worksurface at 910mm, is there a hood that I could use in black color - it has to be black. A hole and electric feed has been cored at 1.85m from the floor.
Its is going above a 4 ring induction hob 600mm wide.
Can this be mounted as a standalone i.e. not in/under a cabinet, and ducted outside?
Would it look daft?
Thanks for your help.
google black cooker hoods there are lots of them. If you are wanting a chimney type but worrying about the length of the chimney they can be cut to any length or angle as the chimney is just a cover for the flexipipe/duct in most cases.
I have now 430mm from the ceiling to the 650mm level of the hood from the hob (induction).
I have looked all over and blind to it now :) but are there any 60cm black chimney hoods that can do this height?
