Cooker hood quiet & powerful until duct is connected
14 Mar 2009
Sussex
I've nearly finished installing our new kitchen. I've fitted a new chimney extractor above the hob that - despite being the £99 cheapo from B&Q - is quiet and powerful... until I connect it to the ducting through the wall.
Our house is ten years old. The wall duct is offset from the centreline of the hob (builder cock-up, I think) so to connect this new chimney to the existing hole I've had to use two 100mm rectangle right-angles behind the plasterboard together with the circle-to-rectangle adapter above the hood. Joining the hood to the new duct is a 1 foot length of 100mm PVC ducting hose.
On the lowest speed setting the hood can easily hold a piece of A4 paper against the filters, but if the duct is connected then it can't. With the duct connected the hood is noisy, rattly and ineffective. Can a short length of ducting with two right-angles have such a massive effect on the efficiency of the hood? What can I do to overcome this problem?
It vents through the (external) wall, through a backdraft flap and then a brick-sized vent. I haven't disturbed those components - the flap and the vent brick are the original ones that the builders used.
I've a feeling my ducting is too small, but to enlarge it I'll have to enlarge the hole in the exterior wall. :(
That's a good idea. That'll show whether it's the duct or the vent that's the biggest restrictor.
It's a 3-speed fan. The performance on the highest setting with the duct in place is worse than the performance at the lowest setting with the duct disconnected. :( It's noisier too.
Our old Neff extractor was noisy and perhaps the small duct was the cause of that.
What are hoods like on recirculate mode? Worth having?
Thanks. I thought that might be the case.
My wife has told me to connect the bloody thing up and just leave it. The only alternative is to drill a much larger hole through the wall and fit a full-diameter vent, which seems like overkill. I don't have the tools to do this so we'd need to fork out for a builder. Sod it. :(
