cooker hood - regulations
17 Sep 2004
Just had a new gas cooker fitted. The installer said the existing cooker hood /extractor was too low/too close to the hob.
I'm not sure if this is a cooker-specific recommendation or something in Building Regs about all cookers/hoods.
I'm sure when originally fitted it would have been done to the standards applying then.
So how worried should I be?
Is there a genuine safety issue?
Is there a Building Regs issue?
There is a minimum distance a gas hob has to be from an extractor, can't remember what it it.
What cooker do you have and what distance is it from the extractor.
Thanked: 230 times
Posted: Thu Jul 19, 2007 8:06 pm Post Subject:
With no manufacturers instructions it is 760mm above a standard hob to any combustible surface.
If the hood manufacturer or extractor manufacturer allows it it can often be dropped to 650mm.
Manufacturers instructions always over ride the gas regs
__________________
Dave
Read more: //www.diynot.com/forums/viewtopic.php?p=647561#647561#ixzz1TncuZJy6
Thanked: 230 times
__________________
Dave
Read more: //www.diynot.com/forums/viewtopic.php?p=647561#647561#ixzz1TncuZJy6[/QUOTE]
you need to check MI of both the cooker and the extractor and must leave a space equal to the largest of the 2 dimensions (if they are different)
