Cooker hood vent through eaves - terminating flat channel?
2 Dec 2019
I have a really stupid question about assembling ventillation pipe.
I want to vent my cooker hood through the eaves rather than go through the roof as I suspect it's cheaper, less effort and less visually disruptive.
The hood has max flowrate at 386m^3/h so a bit of research suggests I can get away with 5"/125mm (or equivalent flat channel).
It's a tight squeeze, so I was thinking of using some flat channel to exit the eaves, which look like:
I was looking at the Manrose catalogue and I can't work out what I need to terminate the flat channel? Can you just cut a hole, use one of the grilles and place the flat channel up against it? Not sure how it connects - if indeed it does.
I know there are 'airbricks' that look like a 'connectable' thing, but I don't have much vertical leeway - just 6cm at the outside edge.
A am thinking of using a flexible or 45 degree flat channel connecter at the left hand side is what I was thinking, just not sure if it has to go through an airbrick or can just poke into the 2cm wood of the eave (at number 9 above).
Hope that makes sense - I wish I had a selection of parts to 'play' with to see how these could fit together.
I have a toolstation, wickes, b&q and screwfix handy.
Thanks for any pointers!
I'm sure it's possible. The bathroom, next door, is vented that way. See below:
Is a roof vent install reversible? And aren't they pretty expensive?
It's certainly possible - but I'm very VERY wary of touching a roof as a non-expert given they are so important. It's something I've never dealt with.
Things that make me wary:
* I don't know how slate tiles are even held in.
* I wouldn't know how to remove slates without causing damage.
* I don't know how to make sure the overall install doesn't leak.
I mean, I wouldn't know what to remove in what sequence and what to lay on what to do a roof vent install. I hope that makes sense?
That's why cutting a rectangle in a bit of wood and routing a plastic pipe to me seems to be the simplest option. I could be way off, of course!
