Hi Guys,
Is there a limit in distance for a wire from the connection outlet plate to the double oven?
Like most posh kitchen layouts we are looking at putting our double oven which is 4.5kw max on the other side of the kitchen along with other tall units and the integrated fridge/freezer.
The hob is staying were it is.
The 45a double pole switch, near the hob, has under the worktop a dual 45a connection outlet plate which are both currently connected too.
Can I return the oven connection wire from the dual plate back up the wall, across the ceiling and then back down the wall the oven is against to a single 45a connection plate then attach the oven?
Please excuse the poorly altered image. I meant the wire to say oven not hob.
Thanks.
Thanks.
