Hi all,
I've spent a couple of hours trying to find an answer in the archives without success, so apologies if this has been asked before!
We've just ordered a new Dual fuel cooker (2 electric ovens, gas hob) to replace a gas cooker. Now I knew there was a 40A MCB on the board, but it turns out that the socket it feeds is at the wrong end of the kitchen.
Is it OK to extend the 6mm2 cable by using a junction box and more of the same cable?
The cooker is rated at 7.4kW, so I believe that 6mm2 is OK for the job, and I intend to run the cable at high level in surface trunking as I've got a wall full of units and a double doorway to negotiate to get to where the cooker needs to go.
Thanks in advance for any help you can give.
