hi please can you advise me on the following
I was advised by my sister that her cooker switch was making a crackling noise so I popped over to have a look.
its a cooker switch with single socket with neon , I pulled the fuse and unscrewed the switch cover, replaced the fuse and tested between line and neutral and line and earth and get 240V on the supply side...
I tested on the load side and get nothing is this simply down to a faulty switch ?
The Neon does light up when the cooker switch and single socket switch are on
cheers
Stephen
cheers
Stephen
