HI THERE IS THERE A REGULATION THAT THE COOKER SWITCH
SHOULD HAVE A CLEARANCE OF 50mm FROM THE COOKER HOB
EG THE HOB BEING THE SAME WIDTH AS THE SPLASH BACK (WHICH IS MOUNTED TO THE WALL ) SHOULD THERE BE A DISTANCE OF 50mm
BETWEEN THE SPLASHBACK AND THE COOKER SWITCH ?
IF SO WHICH GUIDE DOES IT STATE THIS IN I HAVE THE 16th EDITION REGS BUT I CANT FIND IT MANY THANKS TIM LEE
