The wiring for the electric cooker ran originally from the consumer unit under the landing floor across to a brick wall dividing kitchen and dining room.It then ran down behind plaster in steel conduit to the cooker switch.
I have now made the dining room into the kitchen and want to run the cable a couple of feet to the side, through the wall into the new kitchen.The existing brick wall for various reasons has been studded and plasterboarded to give a neater run to the wall .The cavity between the plasterboard and brick wall being approx 3".
My question is can I run the new cable inside round plastic conduit on the surface of the brick wall but behind the plasterboard.
I have drilled a hole through the wall put a piece of conduit through hole to back of the cooker switch pattress, then plastic conduit beneath the plaster and tiles down to the cooker connection plate.
Do I have to run conduit from the consumer unit between the landing floor to the wall or can the cable be clipped along the joist?
I have done lots of electrical work over many years but with the 'new' regs thought I had better check.
Thanks, B
Thanks, B
