Hi all, finding myself in a bit of a fix!
i need to install a new range cooker, it has a 14.4kw rating, i need to know if a 32a rcd with 6mm cable to a bi-polar cooker switch jobbie (with a socket outlet) and 6mm tail is sufficient for the cooker without causing nuisance trips or worse... the cable is less than 50mm into the wall plaster and does not run through insulation, am sat here waiting to wire it in and dont want to burn the house down.
also, do i need a switched fused spare for the extractor?, its only a 3 amp supply but says it must be hard wired and not plugged in.
many thanks in advance..
stu.
stu.
