cooker wiring
2 Nov 2006
hi guys,
ive moved a cooker switch from its original possitioning to more suitable location on same wall.
the cable wasnt long enough so ive jointed it using 60A strip connectors which i am to beleive is suitable however i am looking for further advise on the following.
the cable now runs along the wall behind the cooker space will it need
1/ channeling into wall or ducting
2/ simply clip it to wall
another point where i need help most is with the cooker switch and cooker outlet point.
the scenario was the wiring went direct from meter to the combined socket + cooker switch then to a cooker outlet box on wall, however is it safe and is it possible to make alternative connection as follows:
meter to combined socket switch direct with the cooker directly wired to the switch rather than the cooker outlet point.
cheer
terry
So what you will have is
Fuse board
Accessible junction box with 60a connections
Cooker switch
Cooker
The cooker plate should be retained so that a safe connection is left should you move or (in 10 years) change the cooker.
There's nothing wrong with having a direct cable between the cooker and cooker switch, but good practice would suggest a cooker plate as a demarcation.
