I've a problem with a Redring 9S electric shower. Water has started to run cooler recently on High setting requiring the flow to be reduced to get the temperature up. I've noticed that there is no difference in water temperature when I switch between Low and High settings. I suspected a problem with the heater element. After isolating the shower circuit, I whipped of the cover to check continuity accross the element terminals. Two terminals, connected to the Neutral, appered to be common. I therefore assumed that the microswitch (operated by the High/Low knob) allows power to either one or both of these, depending on whether Low or High setting is selected. I therefore expected no continuity between these terminals with all other wires disconnected from the heater, but there was. Does this suggest that one of the elements has failed. Or am I missing something.
