Cooper Menvier 9750/9850 Alarm
16 Mar 2019
Hi Folks,
Sorry to trouble you but I’m hoping you may be able to help. I have already done a search on the forum and have found some interesting details but no specifics on my issue.
I have recently moved house and hence inherited a Cooper-Menvier Scantronic alarm system. We are about to do some renovation work and I would like to totally remove the panic alarm button that is right next to the bed, and its associated wiring into the control box.
The alarm is a Cooper-Menvier Scantronic. The user guide front cover has 9750 and 9850 on it. The back cover indicates the panic button is wired into Zone 7, there is also a fire alarm wired into Zone 8, there are no more zones indicated. The keypad is a 9930 model.
I don't have the engineer access code but having read the installation guide I feel quite happy to do a 1st stage reset procedure.
It would be very much appreciated if someone could detail the steps required to accomplish this.
Thank you from a newbie and hope I have done everything right and look forward to your replies/guidance.
Malcolm
Thank you Sparkymarka for your response. I have read the installation manual several times and all I can see is detail for how to wire in the 4 wire closed circuit connections on page 17, I don’t see anything regarding removing such connections but would the following steps be correct ? If not could you amend please:
Set zone 7 as NU from the Keypad
Power off the control unit
Remove the front cover, silence any alarm
Remove the battery
Disconnect the wiring for zone 7
Refit the battery
Refit the front cover
Power on the control unit
Silence any alarm
System reset
Thank you.
Either ...open lid turn off with code ... remove panic button wiring , replace with a link ...put lid on , reset with code ...
NOW ...if it's been set for engineer reset , open lid , do a stage one reset , make zone 7 not used remove wires , reset codes box up and test ...
Thanks for the clarification Sparkymarka, will try it out this weekend.
