Copper pipe query - 3/4" or 1/2" - ?
16 Dec 2004
Hi all,
I'm thinking of replacing a cast iron bath.
The existing bath we have has 1/2" copper pipe for the cold
tap, and 3/4" copper pipe to the hot tap.
Does it make any difference which size of pipe we use ?
Use a 3/4" olive in a 22mm compression fitting, 15mm will fit 1/2" just.
COld is probably from the mains. If you wish to use a shower mixer you should install 22mm coming from CW tank. Otherwise pressure difference causes problems.
