Hi all
Theres probably a simple solution to this, but I have chased all of the pipes for my central heating into the wall. To avoid having joints in the wall I intended to put a 90 degree bend on the end of the pipe then join onto the pipework on the wall in pipe clips.
The trouble is when I bend the pipe I get a shoulder on the bend. If I cut back as far as I can leaving enough shoulder to solder a joint on the pipe will stick out some 50mm from the wall.
I could stick a 90 degree elbow on the end but thats what I want to avoid.
Any neat solutions?
I'm using a rothenburger multi bender and following the instructions so I presume the shoulder is normal?
Any neat solutions?
