Copper Push-fit fittings
29 Aug 2005
I have never used these type of fittings before. I always use soldered or compression joints.
I have a small alteration job to do and the first joint will be very awkward to get to. Using a push-fit fitting will make life much easier.
From a plumbers point of view:-
1.what do you think of them
2. are they as reliable as a soldered joint
3. how long do they last
Thanks, :?:
I have looked at these and they seem just as good as plastic. Yorkshire tectite do 2 versions, the more expensive (can't remember the name :oops: ) keep the electrical continuity between the pipe.
The only problem I have found is finding somewhere that sells in a small quantity.
Have used them and they last ok. Only problem is they are harder to demount thamn the plastic speedfit.
Thanks, :?:
1. avoid.
2. not in a million years.
3. an unkown quantity as they haven't been around that long.
use compression, avoid any pushfit.
Have used Cuprofit on my heating system upstairs, been in a few years now with no problems at all. Would use them again without a second thought.
Yes they are expensive, but the time saved is worth it. Cuprofit
Salem.
