Hi' i'm fitting a towel warmer with the intension of using copper pushfit connectors which will be under a concrete floor when filled
i heard that you should not use push-fittings under ground as they might leak eventually. is there any truth in this? there will be four connectors alltogether i suppose the more there is the bigger the risk!
thanks keith
thanks keith
