E
EddieM
I had an idea, but have no idea if it's a goer. Does anyone know if cordless battery form factors are protected in anyway I.e. could you simply copy them ?
Actually the tools change as well. Quite a few of the cordless tools used by tradesmen today are more powerful and have more inbuilt technology than the tools of ten years ago. Similarly the improvements in battery technology mean that you need the latest tools to take advantage of them, e.g battery and tool overheating safeguards, etc. In real terms after 5 or 6 years many trades tools are grotty and worn out so need to be replaced, but as for £100 for an unwieldy adaptor which can't be used on a large range of tools (the DW converter won't work on the 2nd fix pinners, for example) - I can't see the point.
Depends on the range, but at least some of the technology is in the battery of a couple of manufacturers. DW have crippled their adaptors so that they won't work with the older NiMH generation 2nd fix nailers (amongst other tools ). Apparently these tools can and will draw so much power in heavy usage that they will potentially overheat the new XR range of Li-Ion batteries.
I personally can't see the point in hanging a new Li-Ion battery on, say, an old style DW or Makita combi drill when the newer generation tools are smaller, lighter, more powerful and have longer run times (due to the introduction of brushless motors) than the older models. I know I'm playing devil's advocate here, but that is speaking from a trade perspective - and it's the trades who spend the big bucks on cordless kit
