Hi All
Looking on some advice as to what drill to use for core drilling, have 3 110mm holes and 2 45mm holes through a double thick brick wall to do.
My Erbauer 5kg SDS plus drills clutch packed up and no longer can drill though the chiselling still works perfectly.
Looking at the Hitachi DH28PC but will this work well to drill the the above ok?
Just now I was trying to use a 15 year old Bosch drill with torque control but though it was circa £200 in its day the torque does not seem to work properly anymore. It either on too low and does not spin, or a little higher and it catchs without the torque working or you have the torque to high and its dangerous (just starting with the smaller hole).
So the question is will the Hitachi drill the holes, or do I get a something like the Bosch GBH 2400 and hope the Erbauer does not break down completely. Both have safty clutches opposed to torque or are modern torque controls better and can be used for core drilling?
Any pointers / advice would be appreciated.
